Bill Ebling
New owner of a 1985 Hunter 31Does any one have any thoughts or experience in modifying the stock Jiffy reefing system for the main so that the tack can also be pulled down from the within the cockpit also? The system I have now only controls the clew. I really want to reef efficiently in a single handed manner. I am now making too many runs up to the mast when I reef. Not a very safe place to be in a blow. I have seen complete jiffy reefing rigging diagrams in catalogues but the illustrations have cringles that go through the main sail at BOTH the reefed clew AND tack. On my main I have cringle at the clew but, the tack is configured with two earrings sewn to the sail with strong webbing. First reef earring is on the port, second reef earring on the starboard side of the sail. Here's how I am currently rigged. 1. The dead-end of each the reefing line ties to a sliding padeye in a track on the BOTTOM side of the isomat boom, it goes through the corresponding reef clew, and is lead back the to the internal boom end sheaves, runs THROUGH the boom and exits over internal sheaves near the the bottom of the boom just aft of the gooseneck. 2. The lines are then lead aft to the cockpit as follows: The line turns through a block at the mast step and goes on to double stacked deck organizer (4 sheaves port and starboard) leads through the cabin tunnel into the cockpit. Each line terminates in its own rope clutch. (BTW, I route the outhaul back to the cockpit this way too. The built in jam cleats/clutches at the gooseneck end of the boom are kept in the open position with big wire ties wrapped around the boom).Here's how I currently reef. I head the boat into the wind and command Otto Helm to keep it there. I drop the Halyard at a predetermined mark to bring the earring in the neighborhood of the hook. I pull in the reef line until the new clew is pulled down to boom. I than run up to the mast and set the tack earring in the hook near the gooseneck, then run back to the cockpit to tighten the halyard against it. If I didn't get it quite right (remember the boat is pitching and rocking and rolling), the earring slips out of the hook before I have had a chance to get the halyard tension on. I then have to repeat the whole operation again, and sometimes again.... and again.....and again. Can look sorta like a Laural and Hardy thing. Once the clew and tack are tamed I can go back up under sail at leisure to set the reef points. What I am contemplating doing in the rigging department:1. Don't use the internal rigging in the boom (except for the outhaul) and install a short length of t-track on the port and starboard side of the boom near the reef clew. 2. Add jiffy reefing cheek block cars with integral bails for the reef line dead-end. 3. Lead the reef line from the dead end bail under the boom, up through the reef clew, back to the t-track mounted boom cheek blocks. 4.Continue running the reef lines OUTSIDE the boom to cheek blocks that are mounted on the mast just below and athwart the gooseneck. 5 The reef lines would then run up the corresponding tack earring, back down to the mast step turning block, to the deck organizer and back to cockpit rope clutch. My hope would be that I could release the halyard to the predetermined reef mark, pull in on the reef line until the tack and clew reach the boom and then retention the halyard. No dancing up to the mast several times to put the tack earring back in place. I would not have to go up on deck accept to place the reef points in. Questions:A). Does this rigging solution sound reasonable?? Here are my two concerns: 1). Is the sharp bend put in the reef line at the earrings going to cause pre-mature failure of my reef lines? 2). MUST the reef line at the tack go through a cringle rather than an earring?? On my main sail the reef line will not go through a tack cringle and therefore tack will not be pulled straight down to the boom at the gooseneck but will rather be pulled to port on the first reef and the starboard on the second reef. Won't this screw up sail performance and more importantly put excess stress on the slugs attaching the main to the mast near the goose neck? This looks to me like a damn good set up for tearing the main B.) Should I figure out a way to install the proposed mast cheek blocks on the boom instead as close to the gooseneck as possible? This could potentially releave alot but not all of the lateral pull on the reefed tack. However, there ain't much room at the gooseneck to do this. C.) Is this all just bad technique on my part?? Any suggestions for improving my seamanship to make sure I get the earring in right the first time so I can stop this foolishness and stick with what I have. (KISS principle). I am thinking that this could be done simply by heading up, going close hauled on a port tack for the 1st reef and close hauled on a starboard tack for the second reef. This way the sail won't flog, the earring is always upwind and under the positive influence of gravity, and if I slip I can fall into the main rather then the sea. Is this how its supposed to be done?wfe
