Great Topic -- here's a link to the Dutchman
Someone said "the boom is the most dangerous thing on a sailboat, except perhaps the liquor cabinet."I have been considering installing a Dutchman boom brake (see the related link for more info). However, it seems like a simpler and therefore more reliable method is just to do up something like Matt described. One thing in the Dutchman's favor, is that it works in "set it and forget it" mode as a brake. The only time you have to adjust it is if you want to use it as a preventer, too. I've been running lines to the forward cleats like Matt, and this weekend I am going to try the midship cleats. If that works out, I'd like to put blocks on the deck near the chainplates, and run the line from the mid-boom to the blocks, then back to the cockpit.
