Here's the problem. I want to twist the jib (110) while its fully unfurled but I don't have any jib tracks. The present fairlead is a swivel block positioned on the deck for equal pull on foot and leech. I would like to avoid putting holes in the deck (fairly new boat, perfectly sound and watertight).
Would this work? I run a line through the present block with a new block on it, which the jib sheet will go through. When this new line is tensioned it will pull the new block tight against the old block so the clue will be sheeted at approximately the same angle. As I release tension on the new line it will allow the new block, sheet and clue to rise directing less tension towards the leech, effectively twisting off the top.
I believe there is a line called a tweaker for a spinnaker that works on a similar principle. Once again would this solution fail to work or might it cause some other unforeseen problem such that I should just start drilling?
