Backstay/Forestay/Shrouds
Here is my take on what you are talking about... The fore stay should be pretty tight. I have an adjustable turnbuckle, on mine (about 75.00)worth every penny. The backstay is really ony there if you are going to fly a spinaker (sp) the shouds should be again fairly tight, but not over tight. If you over tighten them, it may compress your deck and crack it or worse. My shouds are tight enough to allow for about 1-2 inches of sideways movement. There was a thread a while back about tuning, and it started by totally disconnecting the backstay from your stern, and backing the mast off so it leans back a bit. Using a screw driver pull own on the adjusters until they shrouds are taught. Do the same on the other side, and make sure that your mast is not leaning to one side or the other. tighten up your forestay, and take a look. to take rake out of your mast, tighten the inner or short shouds, and tighten the forestay. Do the opposite to add rake. If you want to point higher into the wind, then you want to have your mast facing a little forward, but I don't recommend, because these boats want to round up without that. A little rake is good. I say maybe from the spreaders to the top of the mast.... About 3-4 inches is all you need. If you need more, then add the adjustable backstay, and crank on it. If you are using a Boom Vang, that will add some rake as well.reattach your backstay, and set sail!!! Get some help with this, it is way easier and you will not want any of your raising system hooked up when you do this. You want to have as little influence on your mast as possible.Good luckGregg
