What are the advantages of relocating the jib sheet tracks inboard? All I've been able to find is that its optimal for racing. Also, what it the best easy to locate the blocks on the tracks (fore/aft) for each headsail size (110, 135, 150)?
The advantages have been stated. Basically it's to help your boat point better/faster when close hauled into the wind. This is especially helpful when you can control the draft of the mainsail (with a good outhaul setup)because if that's too deep/baggy the the tighter jib sheet location will only cause the redirected wind to blow into the area behind the mainsail luff and stall out that sail's value.What are the advantages of relocating the jib sheet tracks inboard? All I've been able to find is that its optimal for racing....
Generally locate the block more towards the stern for the bigger sails.Also, what it the best easy to locate the blocks on the tracks (fore/aft) for each headsail size (110, 135, 150)?
What I was suggesting was to try something in that way as a "temp fix."I've seen the barber-hauler mod, but is this more of a temporary fix, or can it be used permanently?
You can make it whatever you want.....Many race boats are permanently rigged with barber haulers.... it is very, very common... and is much easier than re running the sheets ..... I think it's easier to barber haul inboard, since most of your sailing you'll want to use the outside position.I've seen the barber-hauler mod, but is this more of a temporary fix, or can it be used permanently?
