Darcy Peck
I am the owner of a 1999 H340. Having just completed my first year with the boat I have a few areas of concern. The non skid gelcoat surface on the cockpit coaming has obvious defects which were repaired at the factory. I have viewed other new 340's with similar defects in the same areas. Must be a problem with the mold. Has anyone had these repaired successfully? I also note a stress crack along the starboard rail near the drain ahead of the arch. I too had problems with the jib sheet stoppers cutting the sheets. I solved this by running the sheets through a fairlead on the arch to a block on the stern pulpit then to the optional spinnaker winch. Works great & frees up the other winches. Another problem I have encountered is the throttle. Will not maintain a constant speed. Gradually slows to near idle speed. Have checked the manual however fail to find any adjustment. Any solutions out there? Problems hoisting the main sail were solved by simply easing the main sheet and ensuring the reefing lines are both free while hoisting. Overall I find the 340 to be a comfortable boat with more than satisfactory performance.
