I would think it would be a pain to tack
Carl -Even with the Hunter rig's relatively small headsails, I suspect there are times when you are grinding fairly hard on the sheet winches. Even if not, remember that you have a significant purchase ratio with the winch, and so you will probably need a similarly significant purchase ratio to be able to hand sheet with the same effort. To me, the amount of line you would need to pull would be too much, especially in short tacking situations. I guess you could rely on the main in those situations, but I wouldn't want to have to.Let us know if you find a system that proves me wrong.Justin - O'day Owners' Web
