Jib sheet problem
RobertB
Hi. My problem is with my jib sheets. My Hunter has the aft winches, which makes single-handing much easier. However, if I roll a jibsheet around the winch drum, it will get crossed when I use the winch handle. If I don't roll the sheet, my conncern is that there is too much load on the teeth of the winch.
Its been suggested to me that the cause is the blocks for the jibsheets are set for the forward winches, so they come in on a bad angle to the aft winches. The cure could be to install some cheek blocks further astern.
Anyone else have this problem? How did you solve it? Thanks.
Jack
Robert
Are you using the turning block that comes with the aft winch package? I have not had the problem you describe. I have attached a picture to show the block
RobertB
Thanks
Thanks. My boat came without the turning blocks--that is obviously the problem.
