Jib Sheet Length
Paul Aubrecht
I've got a 93 Hunter 28 I bought used.It came with no Furling sheets.Does anybody know what length I should buy? Thanks
Steve O.
clarification
Do you mean a furling line, or the sheets on your furling jib? A good rule of thumb for jib sheets is at least 1.5 times the boat length, or 42' in your case--more if you want a longer tail. For your furling line, it depends on the unit, and I can't help you much from here.
Paul Aubrecht
Thanks
It was the JIb sheets.42' will work.I will order pronto.Thanks Paul
