Jib sheet length?
Oct 30, 2019
119
Am replacing the Genoa sheets - anyone know the proper length? Recommendations as to rope?Nicholas H. Walsh P.A.
111 Commercial St.
Portland ME 04101
207/772-2191
Fax 207/774-3940
This email is from a law firm and may contain information
that is privileged or confidential. If you suspect
you were not intended to receive this email,
please delete it and contact us.
[Non-text portions of this message have been removed]
Oct 19, 2019
921
Albin Vega 27 Limerick
Hi Steve and all. Just replaced mine. I was about to buy 2x9m which I
saw somewhere on this forum. Fortunately I measured the old sheets
first - they were 10.5 m so bought a single length of (as Steve said)
10mm pre-stretched polyester.
I attached middle of sheet to jib clew with cow hitch/lark's head knot.
Seems fine.
John V1447 Breakaway
John Kinsella
Mathematics and Statistics Dept
University of Limerick
Phone 0035361202148
Web jkcray.maths.ul.ie
Feb 12, 2008
337
I use VPC 8mm on my 135 for days when we have some wind and 7mm Bzzz on the 142 for those basically windless days. The Bzzz is pretty nice, it's a light weight, flexible, solid braid and has never hockled like the VPC does occasionally. There is also an 8mm Bzzz (2700lb rating vs a 1700lb for the 7mm). The sheet length of 64-66' works well with a cow hitch.
I also switched out my mainsheet with 10mm Salsa on a Harken hexarachet fiddle with cleat lower and ball bearing fiddle upper. I've got much less hand feeding out line on light air tacks now. I think I used about 56', but don't have much extra.
I got most of the line for about .50/ft on ebay from Milwaulkee rigging. -Tim
