Tom
How do you handle your jib sheets with the non-self tailing winches on the 260? I'm used to self tailing winches or daysailors that you really need to hold the sheets at all times. Do you winch in and then use the jam cleat? Has anyone replaced the jam cleat with a cam cleat? That would work best if you can trim without using the winch. Anyone use those blue rings that simulate self tailing winches?Also, can you use the mast raising system on the water or do you need the trailer winch? I'd like to be able to drop my mast to go under bridges at the beginning and end of the season.Thanks for the help
