Jib Replacement - Hunter 25
Steve Hall
Over the weekend I tore-up my jib sail in high winds. I am looking to replace mine, which was the original sail. What size should I get to replace it? Should I go with a 110%, 130%, X? Can you make a recommendation?? Thanks in advance, Steve Hall S/V Helen Highwater 1977 Hunter 25 Cherubini
Jeff D
Roller furling?
If you have roller furling, I would go with the genoa. If you don't have roller furling, but have a storm jib, I would go with the 130. If you have neither, and don't intend to buy roller furling or a storm jib, I would opt for the 110. A less common optiont hese days is to put reef points in a 130 but now I am dating myself.
David Foster
Racing or cruising?
For cruising, the best combo is a furling 110, and an asymetric spinnaker. This rig will outperform a genny in all conditions except going to windward in light air - and most of us cruisers are motoring in those conditions! Racing rules usually penalize the spinnaker, and windward performance is critical, so you would want to think about a furling 135-135, or even a 150 if you often have light winds. Finally, my strongest recommendation is to find a sailmaker you like (locally or online) and develop a sail strategy with him/her. Let them know your plans, and resources, and get advice on the steps that will take you where you want to go. Over two years, we replaced the blown original main and 110 on our '77 h27 with the rig I describe above, and a partial full batten main, all from the local Doyle loft. The results for our week long cruising and day sailing on Lake Erie are: Easy shifting and reefing of the sail plan as winds change is provided by the roller furling headsail, sock on the cruising spinnaker, and sensible main reefing. 20% less time on the engine while reaching on the spinnaker with the full batten (larger roach) main. High performance in heavy air from the tunable main, and reefable 110. The new main also reduced heeling by 5%, and weather helm substantially We kept the 135, but only use it occasionally for racing. Those are my ideas, but I encourage you to think through the question for yourself - that's a key joy of sailing - understanding the trade-offs, making our own selections, and then seeing how they perfoms for us. That's also why we have different rigs, but each can be somehow "right." David Lady Lillie
Bill O'Donovan
Rules of thumb
1. 110 will sail well in heavy wind. 2. 150 genoa will be a bear in heavy wind. 3. 130 is like kissing your sister, a compromise 4. Assemetrical spinnaker precludes 150 and 130.
K
ken matejka
excellent advice from David
I agree with Dave's points--especially about talking to a good, reputable sailmaker. I also recently replaced my old blown out dacron original 110 on my 28.5. I went with a 145 with foam luff for furling down effectively to about a 105. My sail was a carbon fiber tape drive from UK sails with a dacron taffeta added to give durability as I only occasionally race but also wanted a sail that would hold its shape. The difference in upwind performance is dramatic. The boat is much faster and actually heels less in the same wind conditions since the sail is flat and doesn't generate as much heeling moment. If you don't have a roller furling system, maybe this would be a good time to try to get one. I see them quite often on ebay for very reasonable prices. Then, you could go with the larger sail and reef down as the wind comes up.
ted
Steve, just bought a 133 genoa for my 25.5
I bought mine from just up the road from you at Sabre Sails, Fort Walton. I had a 155 and a 110. The 155 was to big for my track and couldnt get a decent sheeting angle on it. The 110 wasnt enough. I love my 133. Had Sabre make a tri-radial out of Pentex. They did a awesome job and at a good price. Check them out... Ted
