jib line sent aft
Dave Oberholtzer
I have a 96 H26 with the wheel kit installed and I am interested in bringing the jib line to the aft of the cockpit so I can do all my sailing easily from the aft of the cockpit and not have to go to the companion way to adjust my jib. Has anyone done anything like this? Thanks for any info. Dave Oberholtzer "hydrotherapy
Dave Condon
Jib sheet
You could spend alot of money with the various ways out there but the easiest and least costly is to get a llongewr jib sheet and install the Harken cam cleats with the riser pads which is the easiest way I found. Crazy Dave Condon PS I did it again. I left my briefcase out to be snowed on. I guess that is why they call me crazy
Steve
Lets try this again
Dave you may want to re-explain your thoughts.. You would still want to remount the winchs back on top of the combing? otherwise, how else could you adjust in heavy air unless you are rather stronger then the average guy?
