Yesterday afternoon we were blessed with some decent wind here in SE Pennsylvania. I got my 222 out and tried out my Genoa for the first time. It worked out great. As I hanked it on, I noticed that my jib halyard is in very bad shape. I am not sure it will even make it through the season. I assume I can use the old one to pull a new one up around the mast? Any tricks or advice would be appreciated.
Thanks,
Dan
Here's Youtube compliment of Sailrite that you can check out.
http://www.youtube.com/watch?v=J4BYQY_2jbU
When I replaced my halyards, I had my mast propped up on the kid's playhouse on one end and a portable workbench on the other end. I had removed the stays and spreaders from the mast in the fall prior to this.
I cut a notch in a short board and put it in the vise of the bench and set the mast in it to keep it from turning.
Then I ran a large darning needle through the side of the whipping of each halyard with a strong nylon twine connected to it and tied it to the end of the halyard and pulled the old halyard out and the twine in.
I bought some 5/16" Sta-Set-X off Rudy and spliced the shackles to each halyard myself. I also whipped the end of each of the halyards and pushed the needle through the whipping with a sailor's palm. Then I used the twine to run the halyard back into the mast. A sailor's palm is a tool made from a combination of leather and metal that fits the hand and it's primary use is to push a sewing needle through heavy material like Dacron sail cloth.
