Jib Halyard for 272
Woody, I installed a halyard and rove it out of the front of the mast truck on my 272 a couple of years ago. When I bought the boat there were only two lines rove through the sheaves at the mast head just as you describe. I suspect that that was SOP for rigging the 272 when it was commissioned. On the 272 there are sheaves forward and aft in the mast truck and you can reeve a line through one of the forward sheaves at the truck so that it exits on one side or the other of the mast step. There are spare sheaves at the step on both sides. The new line can then be led to a deck organizer and back to the cockpit if you so choose. I currently use the halyard as a spare as I don't have a spinnaker or any other sail to fly from it. Its most frequent use is to support the wind catcher that I use in the front hatch when at anchor. It also serves as a means of going up the mast. Now I don't have to depend on the main halyard only when going aloft. Now you probably want to know how I did it. When I rove the new halyard, the mast was unstepped.At the end of the previous season I had removed the main halyard and the topping lift and replaced them with two messenger lines. I usually soak the lines to clean them and get them out of the harsh Ohio winter. During the winter I decided to reeve the new halyard from the front of the mast. The following spring during commissioning I disconnected the mast truck and mast step, and using one of the small diameter messenger lines which was already in place from removing the lines the previous season, sewed both the main halyard and the new halyard to the line. The truck and step have to be removed so that the lines can be guided through the appropriate sheaves. I then pulled the two through the mast, rove them through the sheaves top and bottom before reconnecting the truck and step. I finished the rigging operation by messengering the topping lift back onto its sheaves and now have three internally led lines exiting at the mast step.I have done it by going aloft too, but going aloft and messengering a line to exit the mast step at the proper location is a job that requires PATIENCE and a day with long periods of windlessness. My method was to lower a weighted messenger line through the proper sheave at the mast head and have a (VERY PATIENT) partner eventually pull the line through the correct sheave at the mast step with a small wire hook. It worked and we were very proud of the job, but it is terrifically exasperating because any movement on the boat causes the line to swing away from the sheave location. That's probably all or more than you want to know about reeving a new line through the mast of a 272.Luck and Patience,Tom
