Jib Cunningham for Hunter 23
G
Greg Stebbins
If you’re owned by a 23 then there’s a good chance you’re fairly fanatical about sail trim. I can’t speak for all Hunter 23 owners but for me, I can never get the jib tight enough in heavy air. I keep getting those little loops between the piston hanks. I’ve thought about adding a jib halyard winch (I have an extra one in the garage) but where? The jib halyard exits the mast on the same side as the main (Z_Spar Flexy). The idea of stacking 2 wenches on the starboard side of the mast doesn’t appeal to me and opening up more large holes in a mast that gets bowed as much as mine does is scary. Remember Z Spar is no more. Now, in my opinion, the factory method of attaching the jib tack is a little lame. It attaches to a short wire loop from the bow fitting, which is deep in the anchor well. The lame part is not the fact that the bow fitting is down in the anchor well. It’s great that the jib can be fitted right to the deck because everything but sail cloth is below deck level. It’s that little cheesie wire rig that bugs me (and tends to drop through the hole at the WRONG time!). What I’ve done is to add a small tackle to replace the wire. I used 2 small triple blocks, one with becket and cam cleat. The triple block with cleat is down in the anchor well and the top has a snap schackle which attaches to the jib tack. Now I raise the jib to the top of the fore stay and then pull the tack down to deck with the tackle. The jib is now tight and I can draw the tack right down into the anchor well if I want to or raise the jib 3 or 4 inches of the deck (why?). When I change jibs, I let the tackle out about a foot, which pretty much stops the rig from falling down amongst the anchor line.
Jon Bastien
No more Z-Spar?
Hi Greg, I was able to get parts for my Z-Spar mast through US Spars in Gainesville, FL. They replaced a hard-to-find tabernacle that I broke in a mast-lowering incident... The rep (Tom Thomas) knew exactly which part I needed, and sent it to me in 2 days via UPS (he even threw in some extra pins and sheaves for me...). Only problem I had was getting someone to answer the phone on their end- It took me two days to get a real live human on their end to talk to. They have an on line catalog, at http://www.usspars.com . The phone number is on the site as well... --Jon Bastien H23 '2 Sheets to the Wind'
G
Greg Stebbins
Yo US Spars
Jon, I've had exactly the same experience. Broke the tangs off the mast foot casting on my 1 and only attempt at by-the-book mast raising (also brained myself). I now use the marina mast tower and boat lift. Contacted US Spars after severial tries. Got their last casting. My concern is that the mast itself will go bang! Although in some ways I would welcome it. I'd like an excuse to replace the mast on my 23 with a cut-down J24 mast/boom. They rig about the same and would give me more sail area. The summer winds here are very very light. There are 2 j24's on my dock and I've had a chance to study them over time. Heck, there's every thing from j22's through j30's here. Given that all j's seem to be in a continuous state of tore up and barely patched. They've got good masts and fair booms.
G
Gary Bridi
H23 Jib
I have no problem hauling the jib in as far as possible using the stock winches..so I dont think that thghtening upwind is the problem. Better upwind on the H23 needs a larger headsail. Does anyone have a 135 or 150 on a H23 (wing Keel Version, mine is a 1992)? If so I would be interested to know how you have it rigged. Where are the tracks and does the lifeline get in the way? Is the sheet outside or inside the lifelines? thanks Gary
G
Greg Stebbins
Gary Bridi of PA
I have a 155 on my 88' 23. You probably have a slightly different mast/spreader configuration than I do (your spreaders are a bit longer than mine). I run the 155 sheets outside the stays but inside the safty lines. My tracks end right center front of the winches and run stright forward from there. It looks a little odd maybe but with my short stsys I can get away with it. The closer you haul, the higher you point. You can shorten your stays and move your chain plates if it is important enough. Some have.
