Jib Attachment for hunter 23.5
Brian Wells
I recently purchased a 1993 Hunter 23.5 foot boat. The jib appears to attach next to the forestay on the deck. When the jib is attadched this low, it runs into the life lines especially when sailing down wind. Anyone know if this is normal or if you have had the same problem? thanks
Rick Webb
Yep, That is How it Works
I did put a snap shackle on the jib and a long D Ring on the bow that brought it up some and made it easier to attach.
Mark Major
Same on '86 H23, but
when serious about getting down wind I detatch the lifeline from the upper part of the pulpit and reattach it to the base, having found raising the sail from the deck as in the previous response sacrifices performance. I have also repaired the sail due to this chafing.
Sean Coerse
The Fix
You can attach a pennant (extra piece of line or wire with a shackle)to the tack of the jib that will raise it high enough so the clew of the jib clears the life lines. I have a CDI furler and because of the hight added by the furling drum this isn't a problem. I dont think it will be a major problem either way.
