Don't Combine The 2
Dale, I hope your not thinking of towing your jet ski, using a 3h.p outboard on the back of your 25? Under calm conditions a 3 hp will move the boat about 2 knots. Add in any head wind, chop, currents or tide, you may reduce that to less than a crawl. Add a towed jetski into the mix and you could be going backwards. I lose about 1 knot in boatspeed (5 to 4)on my 25 (10 hp) when towing a dinghy. My fear here is that you may need a reserve of power, not available, to get you out of harms way.As far as steering your 25, I should think a jetski tows as well as an anchor. It could also be wandering all over the place, unless you set up a double bridle. Sorry for sounding so negative, but the combination doesn't add up in my opinion.Don
