Jedda 22 Specs
Here are the Specs (Thanks Tasybear TSP)
JEDDA 670 SPECIFICATIONS
HULL Material GRP
LOA 6740 mm (22 ft)
LWL 5756 mm (19 ft)
Beam MAX 2081 mm (7 ft)
BM RATED 1940 mm
MASS 1510 kg
DRAFT (FIXED KEELS) 580 mm
INT.BALLAST 204 kg
KEELS MASS 318 kg
TOTAL BALLAST 522 kg
AUXILIARY POWER
Outboard, Diesel, Outboard in well, (7.5 or 8hp)
SLEEPING ACCOMMODATION
4-5 berth (1 double V berth) 3 single berths
GALLEY
Metho 2 burner stove, sink, shelving.
TOILET
Porta Potti under V berth
STORAGE
Under bunks, side pockets, anchor locker, cockpit lockers
SAILS
Main 8.4 square metres
Genoa 13 square metres
Spinnaker 35 square metres
RIG TYPE
Single spreader, non tapered, mast head, LOA 7.3 metres
KEELS
Twin swing bilge keels, (patented action, 20 turns to lift)
Total weight with mechanism 338 kg.
Or Twin fixed keels
