- Oct 22, 2014
- 23,789
Over the past few years we have had several discussions about Jacklines and Tethers. Some have been for a specific boat i.e. 38 Hunter owner or The Solo Sailor.
Lets start with a definition of terms.
I had to discard most of what I learned about the set up of Jacklines once I read the information and discussion developed by John Harries of ACC.
Harries recently added this article to his Tips for sailors. Sidedeck Jacklines Worse Than Nothing?
Reading the testing done by the Practical Boat Owner crew may be eye opening. Is it safe to use a tether? - Practical Boat Owner
Sailing is an exciting sport. Bringing your crew home safe is an obligation we as boat owners take on when we invite guests to experience our sporting activity.
The Jacklines on SV Hadley run from the cockpit to mast and then to a strong folding padeye on the foredeck - 2 lengths of about 8ft between hard points. Tethers are attached to the jacklines. Using them you attach the tether to your harness point. The tether slides along the deck to the next hard point. You proceed forward clipping in the next tether, then unhooking the last tether. This means you are always attached to the boat. The length of the tethers is designed to allow you to move about the boat but keeping you inside the life lines and out of the water.
BE safe.
- Jackline - A line or strap attached to the boat in two places running along the deck. It is designed to be a safety line onto which you can connect a line to your body. You can use the line to grab and hold should you be sliding across the deck.
- Tether - A length of line you attache to your body (harness) that you can tie to a strong point on the boat or you can attach to a jack line and let it slide along the jack line as you move across the deck.
- Harness - a rig you wear to secure your torso to a tether. There are PFD's that have harnesses designed in the device or you can find just a set of straps designed as a harness to fit over your torso.
- STRONG POINTs - These are specific fittings on your deck that you are going to trust with your life. You use to attach jacklines or tethers to strong points, thus anchoring you to the boat.
BE safe.
