Bob Early
Peggy, if I understand your words and terminology correct, then you'd suggest total reacement of the Jabsco head (approx $150 + S&H) instead of rebuilding the pump assembly (kit approx $50 + S&H) ?Or did I misunderstand the intent of your words in the few articles I did read?In my case, the head works fine, except for the bowl flushdown, which is a little inconvenient to pour additional water into the bowl.The "Through hull" intake is wide open, but has to pass over the anit-siphon break to get there.The pump does "suck out" what liquid there is, with its waste, and transfers it to the holding tank. It was also mentioned that if the pump is not lubricated, it would fail prematurely. Other than disamantling the pump, how would one 'lubricate' the pump ?Sorry if I sound like an ignorant newbie, that because I are one.
Thanks,Bob
