Our manual pump toilet works like a charm except for this; after flushing waste (pump) action the bowl will have an appropriate low level of clean water remaining....then within 15 to 30 minutes-the clean water level in the bowl is much higher. The overfill is definitely not waste water. There is absolutely no odor. We do always leave the seacock open and the pump valve lever closed when not pumping out waste. I am confused...any insight would be appreciated.
Jimongee
Jimongee
