Jabsco Sensor Max 14
May 14, 2022
3
Catalina 30 lake oroville
Dad has an 08 H41DS , about to replace the pump under the galley.
I don’t see Sensor Max 14 anywhere on the world wide internets. The PAR Max has the fittings aimed the wrong way. I have no idea what species of pex Hunter used so I’d rather just get a pump that fits than learn how to add fittings.
Anybody know of one?
Thanks,
Jan 4, 2006
7,469
The head on these pumps can be usually rotated. Check their installation manuals to see.
Pull out a section of tubing and take it to your nearest marine store to compare.
Sounds like plumbing may not be not your main forte in life. You might want to find someone who is a little more familiar with boat plumbing and avoid soaking wet sox when you least expect it.
Sep 11, 2011
432
Hunter 41AC Bayfield WI, Lake Superior
Most of the pumps are the same ITT wobble pump with integrated pressure control. I am pretty sure that the fittings on that pump will plug right into the west marine branded pump. There are others out there too, just all re branded.
