K
Ken
Peggy, I should have listened to your advice. Lots of factors, the big one being the budget at the time. Penny wise and pound foolish. We replaced our old Groco last year with a Jabsco. We are now occasionally getting back flow into the bowl, changed the joker valve, helps alot but occasionally still get some backflow. In the dry bowl position get a pressure build up in the pump handle on the down stroke. Holding the wet/dry lever hard over in the Dry bowl position helps, but doesn't remove all the pressure. When the bowl is finally dry, pumping complete, a few seconds later get air bubbles back flowing into the bowl. Seems to work as advertised in the wet bowl position. Level of the holding tank seems to make no difference and the vent line is open. Am I overlooking anything or do I have a case of the "bad Cam" you so frequently talk about.
