Purchased and installed a standard size Jabsco manual head in my H33 in August. We are in port a lot so we use fresh water to flush toilet to keep odors and bacteria down while not using the salt water flush. This is done manually with a small container we keep in the head to fill with water from the sink.Unit had performed flawlessly until last week when we were out and one person on board used the head, and after using he switched the lever over to fill from the salt water supply and then back to the off position. Every since then the toilet pump is very hard to pump and it makes a suction on the sea water inlet hose even though the valve on the toilet and the thru-hull are both shut. My first thought would be that the valve did not reposition when the handle was turned back to the right. Any ideas would be appreciated. Thanks.
