We KEEP having this conversation...
Anything that's thin enough to pour down the toilet will just wash out in a few flushes. If you want to keep the pump pumping smoothly for an entire season, here's how...it's a 10 minute job:Buy a tube of thick teflon grease (available from any bicycle shop for a lot less than any marine source). It's the same lubricant that's in all toilets when they leave the factory...that lasts a season, maybe too.Remove the top from the pump. Depending upon the age of the toilet, that's done by either loosening the hex nut or removing 6 screws.Pur a healthy squirt of the grease into the pump...pump a few times to spread it all over the inside of the pump cylinder. Repeat if you think it needs more.Put the top back on, being very careful not to overtighten the screws...that will crack the pump housing. YOu're done till next spring, when you'll do it again as PREVENTIVE maintenance. That sound you hear is the rubber seals and o-rings being worn away by friction against the pump cylinder...waiting till you hear it or the pump becomes hard to pump is tantamount to waiting till your engine starts to smoke to add any oil.PH IIs need lubrication too. Unfortunately, they don't have a removeable top...you have to take the pump off the base and squirt the grease into it from the bottom, then set the pump back down. But it doesn't take any longer to do that than it does to take the top off a Jabsco and put it back.Steve, you just spent $100 to keep a $100 toilet working, when you prob'ly could have gotten at least one more year out of it for about $3.00--the price of tube of teflon grease.
