Jabsco Lite Flush electric toilet Foot switch alternative
msin99
May 27, 2018
9
Hunter 460 PCYC
Hi all ... I just took possession of a boat that has a Jabsco Lite Flush electric toilet with a foot switch. I'm not a big fan of the foot switch and don't want to spend a fortune on the remote control panel. Has anyone come up with an alternative using one or two rocker switches that could be placed on the wall ?
Dec 2, 1997
8,944
- - LIttle Rock
Jabsco offers a 3 option wall switch for electric toilets that works with any of them...a choice of bring in water ahead of flush, dry flush and the same flush you get with a single button...works with both sea and fresh water toilets...inexpensive, no circuit board. Or you can buy a single wall mounted push button.
--Peggie
msin99
May 27, 2018
9
Hunter 460 PCYC
Thanks for your replies ... I was thinking of something less expensive than the Jabsco options which start at over $100. I would think that this switch might be a good alternative: Amazon.com
msin99
May 27, 2018
9
Hunter 460 PCYC
The foot pedal has a brown and a black wire. The wall switch has brown, red and yellow. Any thoughts on the proper way to connect?
Jun 14, 2010
2,348
I recommend you set it up with with individual control of flush and fill. Combined flush and fill puts too much water into the holding tank, which requires more frequent pump-outs.
