Sandi
Peggy, We have an 05H36 with the Jabsco head. We have several questions - 1. How difficult is it to switch out to a Raritan PHII? Do I need to change any plumbing or is it a matter of unscrewing the Jabsco, throwing it overboard, then putting the new one on? Next, before leaving the boat for any length of time we obviously close the thru hull, but we also take the hose off and pull thru at least a bucket of fresh water with some KO in it. It gets reconnected when we return. The process takes only a few minutes, and it really helps with the "swamp smell". We have noticed since the heat is quite high that even with those precautions we are getting small black "bits" being pumped thru. Any ideas??? No odor after the first pump, but it just looks unpleasant. Thanks. I appreciate it!
