Jabsco Electric "Quiet Flush" Toilet
DPW
Feb 9, 2017
40
Beneteau 43 Hingham, MA
On my 2008 Beneteau 43 the forward head has a Jabsco Quiet Flush Toilet. Recently it stopped working. Fuse is good, power at the switches but it will not activate. I jumpered the raw water pump and it works but not off the switch for it. Is there a fail safe that prevents the raw water pump from working if the toilet pump has failed? The model number for the toilet pump is: 373245-7000 which I cannot find anywhere. There are a few different replacement motors but I cannot determine if they are compatable as a replacement. I am sure this is original equipment and likely should order an entire kit, impeller, gaskets, etc. but don't know how to insure it's compatable. Any help appreciated.
Cheers
DW
NYSail
Jan 6, 2006
3,148
Beneteau 423 Mt. Sinai, NY
I had an issue with my 2005….. ended up ordering a replacement motor assembly.about $250 and works great. Now I have a spare motor.
greg
DPW
Feb 9, 2017
40
Thanks Greg. I called the number Peggie Hall recommended and am waiting for a call back. How did you identify the correct replacement parts? The only thing I could find on the motor, model number, doesn't show up on the Jabsco website. They have a link to "Discontinued Tech Manuals" but it doesn't work.
