Peggy,
Last year I replaced a jabsco manual head with the electric version (model 37010- 1090) in my '87 Catalina 27.
After heeling the boat, I would get water in the bowl. However, although the water looked grey, I wasn't 100% sure if it wasn't just dirty sea water. Since then, I've read almost every one of your posts in this forum!
Anyway, I proceeded to install a vented loop in between the pump and the bowl in the intake line. That and I have shut the intake seacock before sailing pretty much guaranteeing that my problem is with the other kind of "water".
I removed the joker valve and notice that it is much flimsier and smaller than the manual head's version. There was also a gap between the flaps when you look through it... Perhaps that was my problem; maybe it was just a bad valve?
So I proceed to order 2 new ones (the second one being a spare of course). When I opened the package, however, I can still see a gap between the flaps about 1mm wide. The second one has the gap too! Therefore, I am hesitant to even go through the trouble to replace the old one now!
I know what you're gonna say.... vented loop in the waste line!!!
But I just find it hard to believe that is really required here. I've been in several catalinas without a vented loop, and no problem! Frankly, there is just no place to run it without it being overly an eyesore (yes, I know the whole floating condo thing), and secondly, there would always be some water running back into the bowl that didn't climb the loop.
Therefore, I must now, on bended knee, appeal to your infinite head wisdom!
