Brad Cavedo
PeggyI was reading the discussion from long ago at this link:http://archive.sailboatowners.com/archive/archivepview.tpl?sku=2002241084405.41&forumabr=thm&fno=11&model=none&forum=none&andor=wo&keyword=37010&pr=p&ssite=HOW&srt=pdate&start=2&max=100&db=2002I have the same problem now that was described then. The forward toilet fills up with water and pumps out very slowly, if at all. I replaced the pump assembly in October 2003 and it worked fine then. Now, it won't pump out. [Aft toilet works fine and always has.]You made a comment in the above link about "calcuim carbonates" in the discharge line. What is that? I have found a grey, clay like substance in my discharge line. [boat is a 1997 Hunter P42.] It clogged the line last fall but I blew it out by hose-clamping a garden hose to the discharge line and running water at full pressure through it for about an hour. So water runs through the line fine, but the bowl will not drain. Should I replace the discharge hose? This will be a huge job and I don't think it will necessarily fix my draining problem.Any other thoughts on this probem? Many thanks.
