Details
Since the J/28 was designed and built as a cruiser, TPI (Tillotson/Pearson Industries, which builds the J/boat line) probably built them a touch heavy, compared to the standard racer/cruiser J/Boat. Generally, TPI builds things pretty solidly. Practical Sailor said that the J/35 was one of the few production boats that they'd consider sailing transatlantic, because of this. I've only been aboard a J/28 once, that I recall, and don't remember anything that stood out much. Headroom was ok, but space is tight -- you've only got 28 feet. As with any boat you inspect, check the tabbing of the fiberglass into the hull at any bulkheads , and around the floors. If the boat hit something there may be splits, cracks, or crazing in these places. Listen for crackling sounds when you walk on deck or cabintop. That means delamination, which will need to be fixed. Make any offer subject to the vessel passing a survey to your satisfaction. You could do a lot worse than a J/28.
