Tom Boles
OK, so we spent the week-end in San Diego, getting the pink slip and changing the watch on "Running on Empty", our new (to us) 1990 Hunter Vision 32!!!Then on Tuesday, we started taking her apart to go on the truck to bring her home to San Francisco Bay.We managed to spend one night and 2 days on board, so here are the first of my questions:RoE V32 Questions1)Has anyone added engine instruments? What kind and where did you put them?2)Where are your prop shaft zinks located on the shaft?3)There is a small sump beneath the shaft coupling, that would take drips from shaft log & both aft sea cocks. Mine has a 5/8" hole drilled almost all the way through the forward-most athwartships section (stringer). This would allow the sump to drain to the sump area beneath the engine. Becaus the hole is not all the way through, it does not drain. Does anyone have this going all the way through? Has anyone done anything else?4)the two sternmost seacocks-has anyone replaced them? What did you use?5)Has anyone added a real-live shower sump? What did you use?6)How do you keep your boarding/swim ladder in the up position? Mine does not flop down, but there is nothing to hold it in place...7)Has anyone added a fan or fans to the saloon/ cabin/forpeak area? What did you use & where did you put them & where did you bring power from?8)The disco light bar: I was shocked when I saw that it drew like 10 amps!!! Is this normal? Has anyone done anything to reduce the power consumption? (on the other hand, the light is actually rather pleasing overall)9)Hi temp in the instrument panel area below the factory panel: Maybe it's just our FM/CD player ( a high-power (45x4) Panasonic unit), but the CD I took out after playing for a couple of cycles was really hot. Has anyone else noticed this?Thats all for now!
