E
Ed Schwerin
The forward holding tank on my 1986 Hunter 40 Legend is leaking. It appears that it can be removed by taking out what looks like an inspection cover (top) and the forward bulkhead. It is fiberglass. Anyone done this? I suppose that I could repair it in the boat if I could find the leak, but would rather remove it. Does Ronco make a replacement? The pumpout hose to the deck has a loop in it. Should this be straight so no waste lingers in the loop? Thanks for any help. Peggy are you listening? Would it be good to replumb with PVC instead of hoses? Thanks all,
