G
George Kornreich
I removed my starting battery a few weeks ago and went out of town. I was in the middle of having some service work on the generator, but told them we could finish it when I came back. Well, when I got back I called them to finish it, and they said they were able to get it done while I was away. Said it ran just fine. I told them I had removed the starting battery and how on earth did they get it started, and was told they just turned the switch and it fired right up. Yup, it does, and so does the boat engine...using the house batteries!!! As long as the battery switches are on. There is an isolator and a selonoid installed, but I can't figure out how it is wired so this can happen, and for that matter, what the isolator and selonoid are supposed to be doing if I can crank the engine from the house batteries. I suspect that somehow it permits cranking if the start battery is dead, but prevents the house load from draining the start battery... I'm just guessing. Hunter says it's normal. Any "electricians" out there who can explain this to me. Thanks.
