A
Alan
So, I closed on a '94 26 last week and it went in the water a day ago. I came to clean it up today. After reading other posts I realized that it would be prudent to remove all the water from the bilges. Good thing I did as one of the wires from the float switch on the bilge pump was green powder for 2 inches (does not conduct to well!). Anyhow, I found a wet spot under the sink behind the door at the base of the cabinet where it joins the floor. After drying the area several times it became apparent that each time the boat was rocked to starboard, a small amount of water would appear in the area. It tasted salty and appeared clear (clean?). Well I assume that there is a ballast tank leak probably around there. Going to get food dye and place it in the tank to be sure. What kind of work will the repair entail? How much $? My contract with the dealer (authorized Hunter dealer too) calls for the vessel to be delivered in working order so I assume that he will fix it. Otherwise all looks well can't wait to sail.
