My boat has a manual pump that the helmsman can work while desperately steering towards that speck of land that doesn’t seem to get any closer as the water rises. Normally, I use it to strip the bilge sump down below the level of the electric pump.
I disconnected a hose and drained some anti freeze out of the water tank today for access to my transducer patch. The hand pump wouldn’t work. I took the whole system apart which is a bit of a chore since the pump standoffs also serve as the mount for my autopilot.
Here is the cause:
A little sliver of plywood stuck in the output flapper valve preventing it from sealing. It doesn’t take much. Good to use a manual pump like this for some routine task such as bilge stripping so you don’t discover a problem like this when your life might depend on the pump.
Here is the cause:
