I have an 1972 Islander 36 with a Perkins 4107 and Borg Werner gearbox with a 1 to 1 gear ratio (no reduction gear). Is this common on other Islanders with a Perkins diesel - that is, a shaft that turns at the same speed as the engine? As a result, I have to use a very small prop.
