I don't know why you don't get a thru hull transducer. Drilling the exact size hole with a hole saw and installing it in your hull with a poly sulfide caulk like
Boat Life's Life Calk is easy and safe. Then you don't have to worry about shooting through the hull. If there is any air bubbles in the solid fiberglass lamination of the hull, that might cause problems, plus with the in hull variety you have to have a bubble-less mixture between the transducer and the fiberglass to get a good reading. Supposedly in hull transducers are supposed to be able to shoot through 1.5" of fiberglass if there is no core or bubbles.
