Steve
Just finished doing my complete deck and cockpit with Island Girl products, came outgreat!! It's an 1987 boat, it's had about 3 or 4 owners, new to me last year. When I got it the boat had been sitting for a while in the boat yard, the previous owners had bought a new boat and thus neglected my to be pride and joy. Needless to say, it was dirty. The previous owners used softscrub on it, they told me. Not wanting to use softscrub for environmental reasons, and also I've learned softscrub is bad for you gelcoat, I used several earth friendly products to no avail. I finally broke down and used a little soft scrub, then some wax the local marina recomended. The wax left a yellow film, the nonskid areas really yellowed up. By then I had had it, decided to leave it until this year. Well the bottom paint had priority this year, so I just got around to doing the deck and cockpit areas with the Island Girl products, what a difference. First off, the Sea Glow really lifts the dirt out of the gelcoat, you could see the difference as you worked. Secondly, you wipe the dirty Sea Glow off with paper towels, so no rinsing of toxic cleaners into the water!!!, so you use a few paper towels. The Simply Brilliant wax makesthe gelcoat look new and it's as easy as wiping on with a paper towel!!!I got the nonskid kit for the noskid areas. Ok, that you need to rinse, because the cleaner is IG pink, not seaglow. Not wanting to rinse into the water; after I scubed nonskid areas with IG pink, I was able spunge up most of it with a big spunge and wring into a bucket of water. After wiping with clean water and spunging up, the final hose rinse put very little over the decks into the water. I know, the Island Girl products are more bio safe that most other cleaners, but, still I try not to pollute when ever I can.The IG pink cleaned the noskid areas wounderfully, with very little elbow grease. Next, the noskid sealer went on as easy as just spunging it on. Came out great. Just finished up putting the final coat of Simply Brilliant on the smooth gelcoat areas of the deck and cockpit, looks real nice. Thanks Jim for some great products. I highly recomend them. Jim, heres a product I need, maybe you can work on this next, or maybe you have it! There are a few areas on my gelgoat on deck that are pitted, probably because the previous owners used caustic cleaners. Anyway, luckily it's only a few isolated areas. If the pits were small, of course the seaglow and SB filled them nicely, but if they were big and deap, not much could be done. I need a filler of sorts to go under the SB wax. Sort of a "makeup foundation" for those areas. Matching colors would be a probelm, so it would need to reflect the color of the surrounding gelcoat. Then you SB wax over and it's good for a year.
