P.glow for leather, vinyl, glass, NEW boats, cars?
No, of course not!. Poliglow is a single product: water-based acrylic clear coat (with a precleaner) that is designed and suitable for temporary (1 year or more) restoration of old porous gelcoat. It will NOT stick to a new waxed hull , LPU or smooth metal and is too stiff for flexible plastics. The makers specifically WARN against use on new boats. It (last I heard) , and similar products have problem with yellowing (i.e. not for white boats) - this was even posted on this site a year or so ago by a person who chose it over IG for convenience. It's "plus" is that it sets fast and is shiny. It will stick well to porous gelcoat (the pores anchor it) and it will hold up MUCH better than conventional waxes The product has been out there a long time, as has almost identical Vertglas and New Glass (the latter rated equal to P.glow and available on this site. When such product eventually break down they have to be completely removed from the pores (dark colored boats) by stripping, even wet sanding. Howard, the owner of pglow is a friend and is running a small family business, like I am and I congratulate him on steady improvement of the product and a great job of marketing. However as all new boats start to use our products (specifically our Mirror Hard Superglaze product) or pre-apply polyurethane, I think that teh market for water-based acrylics is going to steadily shrink!NOW- BY RULES OF THIS FORUM I AM NOT ALLOWED TO "ADVERTIZE" but what can I say? I will try to be comletely factual and dispassionate. "Island Girl" is a "System" , of my own invention of a handfull of products that, together, is designed to replace most all other products for most all uses. This is a tall order and perfection has been not been an overnight development, given varying climatic /pollution conditions, varying customer interpretation of instructions and varying boats. The only complaints that I have received have all, but one (sooty black streaks - see gelcoat and plastics forum), been associated with slow setting of thickly applied Simply Brilliant Superwax and (to a much lesser extent) our original version of the non-skid sealant (that actually increases underfoot grip).Early last year this last remaining problem was addressed by introduction of a "hotter" resin formulations and a pH corrective metalic catalyst. Set up is now much faster, but not so fast that (like pg and other acrylics) a special applicator has to be used to avoid streaking. Be aware that even professionally applied paints and clearcoats need a totally wax-free and "keyed" (roughed up) surface for proper adhesion. Water-based coatings (because of beading of the water) are even more susceptible to traces of wax - this can lead to tiny blisters ( I have two such customers coming to me this year to switch to the IG system.A brief rundown of some our products line:1. IG Pink even safely removes paint overspray, 5200 etc from delicate surfaces such as upholstery and cloth and yet use with water dilution for most every other general cleaning job.2. Sea Glow. Removes gummy oxidation (fenders etc) and restores whiteness to yellowed white gelcoat, vinyl, hypalon etc, lifelines vents. Removes and kills chalky oxidation in gelcoat conditions and preserves against color fade (ndependent tests) mildew etc. 3. Silkenseal. "Plastic Skin{" sealant seals upholstery, inflatables, vinyl against staining and gumminess. Used as undercoat for conventional waxes (you you can use after cleaning with SG etc). and for "quickshine" touch up of conventional or our Superwax-coated surfaces.4. Clear Horizons. Increases clarity, protects against scratching and acts like a safe "Rainex" for use of clear plastics. I use it on my eyeglasses.5. Mirror Hard Superglaze. Protect NEW boats, car paintwork etc without use of wax or polishes. Just wipe on, even over good (clean) waxed surfaces. I use on my new paint jobs on my classic cars, there is a BMW dealership looking at it for protection in HI tropical conditions, due to feedback from one of their customers.6. Simply Brilliant Superwax. This is NOT a clearcoat, but designed to replace conventional waxes with a simple formula that you just wipe on. Perfection has not been easy from initial shelf-life problems to slow setting (causing soaking in and dull spots on old porous gelcoat) dirt sticking to uncured surface and dull water marks (also when not fully cured). It is a true WAX (synthetic though) -based product with the protective advantaged (water beading for 3 YEARS on my boat that has just recently been redone) but being wax-based will get some dark run off streaks (not seen with the Superglaze),I apologize to anyone who had problems with early versions of this product, but all problems are easily fixed and I am available virtually 24/7. There are follow up e-mails to root out any possible complaints and a money back guarantee. On this site, anyone is free to post their experiences which have been overwhelmingly positive.7. Non-skid sealant. The surface is NOT slippery when wet and it is easily applied. The ORIGINAL formula was developed be testing on my own boat and by a beta testing group chosen from members of this site. It is optimized for use on old porous, stippled gelcoat decks (like mine) and can prevent staining of the decks by oil, cetol etc. Bird droppings just rinse off. Developed for use in warm weather, slow setting (thick applicaton, colder weather) can lead to foot-marks, dirt sticking etc. Although easily fixed, I introduced a catalyst to help with set up in less than ideal weather, and a new formulation (based on the Superglaze) for NEW or non-absorbent decks where only a thin coating is necessary or desirable. For logistical reasons, this may end up as THE final formula.So there you have it - the contents of our kits. If I did not think that our products were overal superior in versatility etc, I would have just gone sailing instead of working so hard for TEN YEARS! In the words of Lee Iacoca - if you find something better - get it! However, don't give too much credence to to claims such as "four years protection" etc that supercedes even what Pract Sailor claim. There must have been reapplicaton or protected storage. Even a new LPU job will not last that long in the tropics or in Texas (see IG testimonials in the Chandlery of this site), Although our products (on white gelcoat) gave beading for 3 years (video to be posted in next few days) , the surface on the sunny side had definately dulled.One last thing. My mail order customers have repeatedly lobbied Practical Sailor to test our products. The reply was "They will get to it - but now they are doing a big test but did not include us! If you want to do your own side by side, I can send product samples and pieces of gelcoat for free. They will also be available at the Sail Expo.Next day or so - video of what the results look like and how apply (see gelcoat and plastics site).Aloha Nui!Jim W
