watch loading strength
Joe, ganging together the singles, doubles, and triples is the usual way to get 4-6 line clutch setups, but maybe a more important factor is watch the advertised loading strength of the clutch. The Garhauers are only offered for the small to medium sized lines (up to 5/16 inch) and in spite of having metal bodies their loading strength is only in the middle of the range (about 1000 lbs/sq. inch). A better investment might be to buy clutches that hold medium to large lines, as their loading strength is much greater--as much as 2900 lbs/sq. inch for the Lewmar Superclutch triple. The brand names you're looking for are Spinlock, Lewmar, and Harken; for deck organizer sheaves also look at Schaefer...
