Differences .....
Gary Stiffness is not a characteristic of the Perry etc. designed cutters: Valiant, Baba, Tashiba, Tayana, etc. etc. Most all these 'designs' have a Length to beam ratio of somewhere 3:1; quite narrow in comparison to the more modern 'sled' standards. These boats are initially tender to about 15-20 degrees over and only then stiffen up .... which yields a kindly 'sea-motion'. Over 20 degrees (especially the full keel versions) and they begin to slip to leeward; hence (and yes indeed), the first reef (or radical flattening) goes in at about 18kts. "Stiffness" for more modern boats comes primarily (probably) from form stability (wide beam) rather than weight. A heavier boat wont or cant accelerate out of a tack as fast as a light weight; plus, these arent as 'easily driven hulls' so they must carry more weight aloft (weight again) as spars and larger sail area. There are benefits of 'heavy' especially when on passage as their slower roll periods leave one less tired out and beaten up ... called "sea-kindly". Also, these boats are designed as cutters and therefore not for upwind perfomance (as a sloop) but from beam reach on down, specifically for long haul, days/weeks on end - tradewind sailing. This is where the staysail rigged boats outperform most other designs. The weight in these boats comes from the robust design .... safety factor of 'strength of materials' of approx. 6:1 instead of the 'usual' 2.5-3:1 for a 'coastal' design; that's why such a blue water boat can withstand a battering for days on end and where a coastal boat held long in storm conditions simply falls apart. Sure, light weight and constant reefing up and down can accomplish a level playing field .... but that gets real old and quickly tiring on a passage. Better to just leave it and press on ... in comfort. Once you make hull speed it makes NO difference how much or little sail you have up. Fred - Not to pick on your friend but if a Tayana is hobbyhorsing as you describe; then, by removing many hundreds of pounds of windlass, chain, stowage, and fuel from the bow, etc. getting the boat back to it proper weight/trim and loading distribution, he'd have given you much less ego satisfaction... as he's got a longer waterline length -- and if a full ~1200 sq. ft. 'up', should have left you well 'back in the chop'. A loaded bow is great for downwind but certainly just the opposite for beating. You're obviously not telling the other half of the story or do you only 'ambush race' upwind? Sloops are always better upwind because of their much tighter tacking angles ----- too bad that you wernt 'racing' downwind (in 25+) as Im sure even with his higher PHRF rating (174 vs. ~145) but longer waterline length he'd have left you far behind in his wake. Its always fun to watch an IOR 'broach coach' struggling downwind with a full press of sail on; ..... a leisurely Sunday morning breakfast in a cutter. ;-)
