Add tach -- or not
The Yanmar Tachometer setup is essentially simple. A "sender", which counts flywheel teeth screws into a threaded boss on the flywheel housing. The instrument goes into a hole provided in the engine control panel -- this gets tricky; some have the "A" panel with no space for the tach, some have the "B" style with a hole for it but no tach, and some of us lucky ones have a hole filled with a functioning tach. The plug-in wiring is probably already on the engine, but depending on the panel style, may or may not be there going from the engine to panel. Installation should be a simple 1-2-3 affair. There is NO CALIBRATION. The only thing is you have to make sure the number printed on the face of the tach matches the number of teeth on the flywheel.Do you really need it? Probably not. Is it a nicety? You betcha. You will undoubtedly determine it's necessity based on the price.
