Is rigging tape evil?
Interesting question. It depends on how and where it is applied. The most common use is to wrap turnbuckles to cover cotter pin tails. Since turnbuckles are typically chromed bronze crevice corrosion is not an issue. The tape is often open at the top and bottom so air can flow freely.
The residual adhesive is sometimes an aesthetic issue.
DArcy
Feb 11, 2017
1,786
Islander Freeport 36 Ottawa
I use rigging tape to hold the spreader boots in place over the shrouds. I have not noticed any corrosion but I have only visually inspected. Come to think of it, I just wrap the boot, not the shroud.
  • Helpful
-na -NA Anywhere USA
On trailerable sailboats, I used rigging tape as well as white 3M electrical tape on the turnbuckles. First you want the turnbuckle body left open on both top and bottom to allow air flow to dry out any moisture and not trap water either. I then added turnbuckle boot covers but never tape them to the shrouds as they are designed to turn if
Sails or lines brush against them
dLj
Mar 23, 2017
4,762
Does rigging tape encourage crevice corrosion by potentially trapping moisture?
I just replaced my lifelines and the attachment ends had been covered in rigging tape for many years (possibly 20 years?).
I did not observe any concern along the lines of your inquiry.
dj
Sep 24, 2018
3,987
Catalina 30 MKIII Chicago
I found a cotter ring that was ready to fall out during my annual mast inspection. Knowing how rigging tape can reduce the chance of a pin falling out, I wrapped the tang and the pin. That's when it dawned on me that there's a possibility of crevice corrosion on the wrapped tang
