On my Beneteau 36 I do not have a macerator. The toilet will dump into the top of the holding tank or directly overboard through the thru hull valve. The waste exits at the bottom of the tank where you can connect to the deck pumpout. It also Y's to the thru hull valve. The bottom of the Poly tank is approxi1mately 1 foot above the thru hull. There is no macerator. My prevous boat had a macerator above the tank. The hoses are all approximately 1.5 inches. So, would solid waste exit without a macerator? I've heard of gravity waste systems but I'm not familiar with them.
Thanks,
Greg.
Thanks,
Greg.
