C
Chuck R
As the rudder mounts to the boat, there is a line threaded up from the rudder blade through the metal top part that holds the tiller in place. Then runs along the bottom of the tiller to a quick release cleat. As I read this design, the blade pivots up should the blade hit bottom. The line holds the blade down in the steering position. My question is first, when this line is on the quick release cleat, how can the blade swing up if it hits bottom while on the cleat?? If I release the line the blade floats up by its self. ( at least it does in the spring launch until the wood core soaks up with water then it stays down about mid season ).Now this leads into my second question (the reason it soaks up water ). This line threads through a hole in the center of the leading edge of the rudder blade to a larger hole drilled about 1 1/2 " aft on the blades leading edge on the starboard side. This hole does not go through to the port side. The line gets a stop knot tied to its end so it can't be pulled back through once the knot is pushed in the starboard hole. Looks to me that this is where water intrusion occurs in to the wood core through these holes. Core gets soaked, expands and then the blade does not want to swing up. So my question is, Is this a factory intention or do I have a Rube Goldberg and what am I supposed to have?
