i am curious.. i read on a web site that the owner used a bottle or two of cheap vodka or gin to winterize his boats water system instead of the pink antifreeze (propylene glycol)what do you think about using ethanol for the potable water system only???i would still want to use pink or permanent in the engine heat exchanger for its non-corrosive qualities and use pink in the head to avoid damaging sealsbut in the potable water supply is drinking alcohol (ethanol-NOT denatured) all right???what are your thoughts???
