On one occasion under very difficult circumstances which I won't go into I had to lose my anchor and anchor line. I had to cut through the cable to let it go so fixing the bitter end was not a major problem. If you have a hatch in your waterproof bulkhead you can attach it to the same point as at present.Mike On Monday, 31 July 2017, 3:10, "walt judy brown allore bestvega@... [AlbinVega]"
AlbinVega@yahoogroups.com wrote:
Gene are you using chain or line? Walt
AlbinVega@yahoogroups.com AlbinVega@yahoogroups.com on behalf of gene_neill@... [AlbinVega]
Sent: Sunday, July 30, 2017 4:06 PM
To:
Subject: [AlbinVega] Re: Is a Vega's hawse pipe too small?
This message is eligible for Automatic Cleanup! (
AlbinVega@yahoogroups.com)
Add cleanup rule |
More info
Thanks, John, I thought that would be the case.
I have removed the forward bulkhead, and applied a layer of heavy biax cloth the the forward side. I plan to epoxy the bulkhead permanently to the tabs it was screwed to, then make a thick epoxy plug for the bottom. I have made a cover for the access hole in
the bulkhead, glassed the forward side of the cover, and will install it with screws and a neoprene gasket so there will always be access to the inside of the locker when needed. My plan is to then install a through hull drain on one side (or both sides) of
the hull.
I'll need to buy and install a larger hawse. I notice they are almost all oval shaped, and have no covers - but I don't see this as a problem, since any water gaining ingress will quickly drain out.
One thing I haven't decided is how to secure the bitter end of the rode inside the locker.
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031 --
#ygrps-yiv-2047224828yiv8636380031ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-mkp #ygrps-yiv-2047224828yiv8636380031hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-mkp #ygrps-yiv-2047224828yiv8636380031ads {
margin-bottom:10px;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-mkp .ygrps-yiv-2047224828yiv8636380031ad {
padding:0 0;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-mkp .ygrps-yiv-2047224828yiv8636380031ad p {
margin:0;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-mkp .ygrps-yiv-2047224828yiv8636380031ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-sponsor #ygrps-yiv-2047224828yiv8636380031ygrp-lc {
font-family:Arial;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-sponsor #ygrps-yiv-2047224828yiv8636380031ygrp-lc #ygrps-yiv-2047224828yiv8636380031hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-sponsor #ygrps-yiv-2047224828yiv8636380031ygrp-lc .ygrps-yiv-2047224828yiv8636380031ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031activity span {
font-weight:700;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031activity span span {
color:#ff7900;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031activity span .ygrps-yiv-2047224828yiv8636380031underline {
text-decoration:underline;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 .ygrps-yiv-2047224828yiv8636380031attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 .ygrps-yiv-2047224828yiv8636380031attach div a {
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 .ygrps-yiv-2047224828yiv8636380031attach img {
border:none;padding-right:5px;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 .ygrps-yiv-2047224828yiv8636380031attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 .ygrps-yiv-2047224828yiv8636380031attach label a {
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 .ygrps-yiv-2047224828yiv8636380031bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 .ygrps-yiv-2047224828yiv8636380031bold a {
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 dd.ygrps-yiv-2047224828yiv8636380031last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 dd.ygrps-yiv-2047224828yiv8636380031last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 dd.ygrps-yiv-2047224828yiv8636380031last p span.ygrps-yiv-2047224828yiv8636380031yshortcuts {
margin-right:0;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 div.ygrps-yiv-2047224828yiv8636380031attach-table div div a {
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 div.ygrps-yiv-2047224828yiv8636380031attach-table {
width:400px;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 div.ygrps-yiv-2047224828yiv8636380031file-title a, #ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 div.ygrps-yiv-2047224828yiv8636380031file-title a:active, #ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 div.ygrps-yiv-2047224828yiv8636380031file-title a:hover, #ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 div.ygrps-yiv-2047224828yiv8636380031file-title a:visited {
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 div.ygrps-yiv-2047224828yiv8636380031photo-title a, #ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 div.ygrps-yiv-2047224828yiv8636380031photo-title a:active, #ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 div.ygrps-yiv-2047224828yiv8636380031photo-title a:hover, #ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 div.ygrps-yiv-2047224828yiv8636380031photo-title a:visited {
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 div#ygrps-yiv-2047224828yiv8636380031ygrp-mlmsg #ygrps-yiv-2047224828yiv8636380031ygrp-msg p a span.ygrps-yiv-2047224828yiv8636380031yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 .ygrps-yiv-2047224828yiv8636380031green {
color:#628c2a;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 .ygrps-yiv-2047224828yiv8636380031MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 o {
font-size:0;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031photos div {
float:left;width:72px;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031photos div div {
border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031reco-category {
font-size:77%;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031reco-desc {
font-size:77%;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 .ygrps-yiv-2047224828yiv8636380031replbq {
margin:4px;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-mlmsg select, #ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 input, #ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-mlmsg pre, #ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 code {
font:115% monospace;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-mlmsg #ygrps-yiv-2047224828yiv8636380031logo {
padding-bottom:10px;}#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-msg p#ygrps-yiv-2047224828yiv8636380031attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-reco #ygrps-yiv-2047224828yiv8636380031reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-sponsor #ygrps-yiv-2047224828yiv8636380031ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-sponsor #ygrps-yiv-2047224828yiv8636380031ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-sponsor #ygrps-yiv-2047224828yiv8636380031ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-text {
font-family:Georgia;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-text tt {
font-size:120%;}
#ygrps-yiv-2047224828 #ygrps-yiv-2047224828yiv8636380031 #ygrps-yiv-2047224828yiv8636380031ygrp-vital ul li:last-child {
border-right:none !important;}
