When I asked here on the forum which should come first, the traveler or the main, it was unanimous to go with the new main.
I did and it was everything you guys said it would be.
So now I can ask Santa for the new main sheet traveler or a new 110 jib.
Current jib is probably original but appears to be in decent shape as far as integrity goes.
The jib sheet turning blocks are fixed which I know hinders good sail trim. Replacing the fixed blocks with tracks is out of the question because of the limited deck space and we enter from the bow. Admiral does not need more tripping hazards.
Considering that, will a crisp new jib increase sailing trim and performance as much as the new main did or should I go with the new traveler for the main first?
Thanks
Thanks
